7 members (3B, Phak1, 1955 1 Series, Gib70, Joe H, KEVINSKI, 1 invisible), 133 guests, and 2 robots.
Topics128,092
Posts1,056,451
Members48,443
#1471424 10/17/2022 4:36 PM
I just picked up a 1948 3800 pickup. Tie rod was so bent, rainbow-style, such that it created probably 45 deg. of toe-out on the front wheels, and we had to cut it in half in order to straighten the wheels to load onto my trailer.
So my question is, what is the difference between a 3/4 ton and 1 ton tie rod? It looks like the parts houses (Classic, COT40s, Jim Carter, etc) stock a tie rod for 1/2 and 3/4 tons, but not for 1 tons.
Thanks!
1953 3600 Pickup
1946 Fleetline Aerosedan
1948 Hudson Commodore
The tie rods are different between 1/2 & 3/4 ton and 1 tons.
Here's a snip from the parts catalogs. It has specs (length and thread dia and pitch) that should help you find what you need.
Looking at a RockAuto listing for tie rod ends (they only have the left side), the 3800 tie rod apparently has internal threads.
Try Rare Parts. $88 each for the 3800
https://www.rareparts.com/search?make=Chevrolet&model=Truck&year=1948
All parts made in the United States
1950 Chevrolet 3100 (Ol' Roy)
I don't know about Chevrolet but in GMC the one ton uses a heavier tie rod than the 3/4 ton, but it will fit. We used to routinely replace 3/4 ton tie rods with one ton tie rods back when we could still find them.
Thanks for the link, Otto! Looks like it's out of stock at the moment, but I'll keep an eye on them and give them a call when I'm ready to proceed.
1953 3600 Pickup
1 Offline
I bought the drag link repair kit from Jim Carter some years ago. The listing was for 3100 through 3800. What I got was cups too small for the 3800 and springs much softer than the original. I needed to replace a broken spring so I had to use the supplied one. Now the steering wheel is no longer centered and it makes the steering box sloppy. I can't take up the slack when it's off center or it'll bind when it goes over center. I looked at Rare Parts listing for that same kit and it supposedly covers 3100 through 3800. It does not. Buyer beware.
1951 3800 1-ton
In the DITY Gallery
