3 members (Rusty Heaps, Otto Skorzeny, mo2cyl), 158 guests, and 2 robots.
Topics128,034
Posts1,055,536
Members48,425
#1471103 10/14/2022 8:15 PM
I'll be changing my 41 Chevy to 12 volt while doing all my projects to it. Can I keep the 6V horns by merely changing the horn relay to 12V, or should I keep the 6V relay and install a voltage resistor in front of the relay?
ponder48 #1471110 10/14/2022 8:35 PM
The fact that you are not working on a truck almost got your post deleted. In the future just ask your questions but don’t tell us what your working on. This is after all a Truck site. Thanks
ponder48 #1471123 10/14/2022 9:52 PM
Sir Searchalot
Sir Searchalot
Yes...in front, meaning before the relay. Voltage reducer at Classic Trucks of America.
Some folks on here just run the horns on 12V with short toots.
the original 41 cars did not have a horn relay for a single horn set up.
The relays being sold for 40's and up old vehicles are not voltage specific. It's all about the voltage the horn wants. You could put the reducer on the relay input or output. (front or back), With those relays.
ponder48 #1471135 10/14/2022 11:03 PM
O Online: Content
When you say the 6v horn is run with short toots on a 12v system, is that because of some sort of damage that might occur with a long blast or is it just because the horn will be "too loud"?
Personally, I don't think there is such a thing as horn that is too loud.
1950 Chevrolet 3100 (Ol' Roy)
ponder48 #1471141 10/14/2022 11:40 PM
Sir Searchalot
Sir Searchalot
Both. Depending on how loud and depending on specific horn design........and to keep some gang banger/road rager from shooting you.
