| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 20 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 20 | I'll be changing my 41 Chevy to 12 volt while doing all my projects to it. Can I keep the 6V horns by merely changing the horn relay to 12V, or should I keep the 6V relay and install a voltage resistor in front of the relay?
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | The fact that you are not working on a truck almost got your post deleted. In the future just ask your questions but don’t tell us what your working on. This is after all a Truck site. Thanks
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | or should I keep the 6V relay and install a voltage resistor in front of the relay?
Yes...in front, meaning before the relay. Voltage reducer at Classic Trucks of America.
Some folks on here just run the horns on 12V with short toots.
the original 41 cars did not have a horn relay for a single horn set up.
The relays being sold for 40's and up old vehicles are not voltage specific. It's all about the voltage the horn wants. You could put the reducer on the relay input or output. (front or back), With those relays.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2021 Posts: 6,722 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,722 | When you say the 6v horn is run with short toots on a 12v system, is that because of some sort of damage that might occur with a long blast or is it just because the horn will be "too loud"?
Personally, I don't think there is such a thing as horn that is too loud.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Both. Depending on how loud and depending on specific horn design........and to keep some gang banger/road rager from shooting you.
