3 members (dunfire, 78buckshot, Hotrod Lincoln), 90 guests, and 2 robots.
Topics128,055
Posts1,055,783
What is the width outside to outside on the Shortbed Stepside frame rails? What is the outside to outside on the same year fleetside? Thanks
Former Workshop Owner
I would think it'd be the same.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
The issue is; I purchased a new chrome rear bumper and new rear brackets. Double checked and triple checked the part numbers. The bumper was from LMC and the proper rear brackets were from Summit Racing. The brackets when bolted to the frame in the correct orientation do not remotely come close to matching the holes in the bumper. We’re talking several inches difference. Btw, I also purchased a new front bumper from LMC and it fits perfectly.
Just trying to make sure someone hasn’t done some sort of frame swap in the past.
The C10 frame should be 42" wide at the frame, but the K10 (4WD) frame is 34" wide at the rear. Front widths are the same for C10 and K10. The vehicle info kit doesn't say there's a difference between stepside and fleetside.
Could be that they share the same bumper, but need different brackets (maybe you got ones for a K10?)
Yep different brackets.
GMK4143807672S '62 C10 rear bumper brackets.
GMK414180755S '62 K10 rear bumper brackets.
Brackets are correct unless miss packed at the manufacturer. I also have a set of fleetside brackets they also won’t fit the bumper. I think I have a bit of fabricating in my future.
My frame is 42” outside to outside. I may have a improperly drilled bumper or miss boxed. Thanks
Looking at the brackets I found, C10's are stamped steel, and K10's are bent flat steel per the pictures on Summit's site.
The brackets sent for C-10 are bent flat steel with compound bends. I have stamped steel on the front but the single bracket I removed from the rear was bent flat steel. I think LMC sent the wrong rear bumper. Visually it looks right but the holes are way off.
The rear bumpers for C-10 and K-10 have the same part number on summit's site.
Definitely something is wrong.
FWIW I received a mis-drilled front bumper for a '77 F-100. They were aware of the problem when I called and didn't even want the first one back. Sent out a correctly drilled bumper right away.
1950 Chevrolet 3100 (Ol' Roy)
Thanks, I will give LMC’s customer service a chance.
