4 members (49Chief, dt235sd, DadsFirstPickup, Hanks custodian), 102 guests, and 1 robot.
Topics128,131
Posts1,056,723
Members48,454
#147018 05/27/2006 10:51 PM
V
V Offline
The tires on my truck, 1933 Chevy 1.5 Ton, read "30 x 5 heavy duty 8 ply". I cant find a reference to this size tire on any of the antique tire websites. Any help is appreciated. I need seven.... dual rears, fronts, and a spare.
thanks, Jim
Look for tires by the rim size. Are they 20 inch rims with 5 inch tires?
Chevy rims for trucks 1931 -1934 were 20in. x 5 in wide. They had a split ring to hold tire on. That was the normal production rim unless you ordered optional tires that held more weight then you could get a 20 in. x 6 in. rim. Tires are available from Cooker, Miller and other vendors just order 600 x 20 tire and tubes with angled metal valve stems. Also order flaps (gutter guards).
34 & 35 trucks are the greatest
V
V Offline
Many thanks gentlemen. Any suggestions on sources for a rebuild kit for the 207....mine smokes bad.
If it just smokes, you may not need a complete rebuild, especially if it sat for several years. Usually the babbit starts to pound before the engine smokes when a rebuild is needed. You may only need to clean up the ring grooves and replace the rings if your bore is within specs. Sometimes running the engine regularly, along with frequent oil changes will free the rings up.
Bruce Bugay in Glen Allen, VA 23059 Phone 804-752-6036 should be able to help you with engine parts. Join us on the VCCA chat site to learn all about your truck and the engine. www.vccachat.org
