3 members (Materman, blanch53, 1 invisible),
125
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 13 New Guy | | New Guy Joined: Feb 2004 Posts: 13 | My owners manual says to use shock absorber oil to lube the leather seal in my hydro-vac unit. Some of the local brake guys say to use a tablespoon of Neatsfoot oil. The book says to fill to the plug level on the back of the unit. Any recommendations? Thanks Stevo | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | I'd go with the local brake rebuilder's suggestion.. You can always add more oiol if needed..
Geoff. (Stick)
49 Chev 4400 51 GMC 350 dump
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
