How do you guys plumb the defroster hoses? One 2" hose from the heater needs to split into two 1.75" hoses for the vents. I guess I need a three-way splitter in but am having no luck finding one. Any ideas? Thanks. Jethro.
~~ Jethro 1954 3100 Back to Life In the Dity Gallery 1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
The stock heater comes with a Y splitter attached. Is your heater stock?
Phil Moderator, The Engine Shop, Interiors and Project Journals
1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes Project Journals Stovebolt Gallery Forum
Dad bought it new in 54 as a service truck. No heater, they bought and installed a junkyard Mopar Deluxe. No defroster. No defroster vents. Added in the 70's was a cut up plastic oil can for a vent on the driver's side and a hose to the outlet on the heater. I have installed 2 vents and would like to find a splitter to hook them both up. Thanks.
Post an ad in the swap meet. I'm sure someone has a spare heater box laying around that you could get a splitter on. You might also find the correct defrost vent fittings. The originals are made of pot metal and screw in place from under the dash. I see that Jim Carter has them made of sheet metal for $20 each. Link
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
My 49 has (I'm told by the parts guys based on diameter) older Ford defroster ducts (I forget the diameter, but smaller than 1.75" - took some time to find the right stuff) and a 30's vintage GM Master.
So for mine, I made one by swelling up some exhaust pipe to match the ducting and welding up my own "Y" with larger pipe to slip over the GM heater. Serves the purpose. Wasn't a big job - nobody can see it anyway.
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver OT Vehicles: 1925 Hudson Brougham Super Six 1950 Chevrolet Styline (Parts) 1952 Canuck Pontiac Sedan Delivery (Well Underway) 1973 F250 4x4 Highboy 1977 F250 4x4 Lowboy
