8 members (68ironhead, jmoore, Joe H, Phak1, 55shaker, 3B, Waveski, 1 invisible), 74 guests, and 1 robot.
Topics128,154
Posts1,056,834
Members48,456
I'm needing some advice. I've searched the forum for the better part of a week and the internet for longer, I believe I'm needing to replace all my tires as they are badly weather checked/cracked. I currently have 8.25-20 on the drivers and 9.00-20 on the steer axle. I have enough 10.00-20 in good shape that I had for my International Harvester project that I'm no longer going to use on it. Would they fit the stock rims? Below is what I've been able to find on the data plates as well as pics of the current setup. I was able to clean off several layers of paint from one of the rims as well. Not sure what the stamping means, but from my research, I believe these not to be the dread "widowmakers", am I correct? Any and all help would be greatly appreciated
Model - HC 451
Serial - 5961
Engine - 270
Transmission - Clark
Front Axle - F460
Rear Axle - Eaton TSDP 16600
Axle Ratio - 6.50-9.04
# of Springs: Front 11, Rear 10, Aux 6
Wheels - Motor
Studs - G
1951 GMC 451
1964 International Harvester v190
Big Bolt Forum Moderator
correct, those are NOT the "widow maker" or Firestone RH-5 rims.
Mike
7
7 Offline
Looks like a 6.50" - 7.00" width, I think it'll be fine with 10.00-20. I'm running 10R-22.5's on my original wheels and they don't bulge, they look correct.
My 52 model 470 series COE has 10.00 20s all around.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Thanks. Good to know.
1951 GMC 451
I plan on working my truck around my property. In your opinion, would there or could there be any issues this the larger tires when loaded?
1951 GMC 451
That is a sharp ride. Quick question, the four brackets that are on the door, where those mirror brackets? Mine has hole in the same location, but no brackets. Thanks
1951 GMC 451
Saw Mill : One thing to look out for is if the fronts will rub when turning sharp. My 7.50s do a little.
7
7 Offline
I plan on working my truck around my property. In your opinion, would there or could there be any issues this the larger tires when loaded?[/quote]
I work mine, nothing real heavy, had 110 bales of hay on it, and didn't even think about tire trouble. The steer tires are smaller metrics so they don't hit any sheet metal. What type of body does your truck have on the rear?
Just to keep things in prospective your 10R-22.5 is NOT the same size as a 10.00-20, it's actually the same size as a 9.00-20. A 10.00-20 is a big tire compared to a 8.25-20.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
thanks for the advise. i'll keep it in mind
1951 GMC 451
78Buckshot-
It's a dump truck
1951 GMC 451
7
7 Offline
With the dump body and that much clearance you can go big on the rears.
Saw Mill: One plus with the 10.00-20 tires is your top end speed will increase at least 5 MPH for any road trips, but a little less gear in the mud.
7
7 Offline
Mike B, thank you for reminding me of the size comparison.
Curious, are you running tubes with your tires? Still new to the whole tube vs tubeless game for trucks. Thanks again
1951 GMC 451
All 20" rims are multi piece tube type.
All 22.5 rims are one piece tubeless type.
The tires are not interchangeable between these two rim sizes, but they can be run side by side if you match there diameters correctly.
7.50-20 has the same diameter as the 8.25-22.5
8.25-20 has the same diameter as the 9.00-22.5
9.00-20 has the same diameter as the 10.00-22.5
10.00-20 has the same diameter as the 11.00-22.5
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B smile
Thanks for the comparison. It's very helpful
1951 GMC 451
Saw Mill My 8.25's rub on a tight turn but not a problem so far,have changed a lot of 10.00 20',s easy on clean wheels.
