4 members (55shaker, IHPWR, Otto Skorzeny, 1 invisible), 76 guests, and 2 robots.
Topics128,026
Posts1,055,403
Members48,422
#1469884 10/06/2022 3:14 PM
rad
Offline
Want to put the original floor starter pedal back in my 49. Question is I have a 1960 6 cylinder and not sure if the flywheel has been changed or if its original or if there the same. I have to purchase the starter to fit (not sure where to buy based on reliability and price or if anyone has a used one) but not sure if the teeth will line up to the old-style starter. Has a new style starter in the truck now. Any help would be apricated
rad #1469888 10/06/2022 3:45 PM
Insomniac
Insomniac
Start by counting the teeth to see if you have the 1949 flywheel or something else.
https://chev235guy.blogspot.com/2020/06/216-235-261-flywheel-pressure-plate-and.html
Gord 🇨🇦
1954 1/2 ton 235 4 speed
rad
Offline
great info.... thanks!
rad #1469896 10/06/2022 4:27 PM
It might be simpler to put a switch on the floorboard to energize the solenoid on your current starter. With a little creative tinkering, a starter switch for a Farmall tractor can be adapted to look virtually identical to the stovebolt foot start pedal.
rad
Offline
interesting thought. thanks
B Online: Content
It might be simpler to put a switch on the floorboard to energize the solenoid on your current starter. Jerry
I've gathered parts (tractor switch, bellows and a big rubber button for the switch) for exactly that project when I put a military 302 GMC into my '52 GMC 3/4 ton. Will use a 12 volt solenoid starter and flywheel is 168 tooth (12 volt) from the same '57 GMC 270. The switch will just pull in the solenoid. I'll wire it through the "IGN" position on the key switch, which will be a little safer than a regular stomp starter which will turn over the engine with the key off.
rad
Offline
Thanks. Sounds like a good way to go
