4 members (49nut, Steelonsteel, klhansen, Shardean), 73 guests, and 4 robots.
Topics128,022
Posts1,055,376
Members48,420
#1469576 10/04/2022 10:04 PM
I'm slowly going over things on my new project truck and came across this hose. I'm not real familiar with 270's, but I'm guessing that this has something to do with the cooling system. If it is, I highly doubt that it's doing much good being kinked like that. Can someone shed some light on it for me. Thanks
1951 GMC 451
1964 International Harvester v190
Saw Mill #1469582 10/04/2022 10:23 PM
The truck probably used to have a heater and the hoses are now just looped together to bypass it. Likely the heater was removed or if its still there, the heater core is leaking.
1950 Chevrolet 3100 (Ol' Roy)
Saw Mill #1469599 10/05/2022 12:06 AM
The threads in the lower thermostat housing and the water pump where those hose barbs are located are National pipe thread (NPT).
You can remove the hose barbs and hose and use NPT plugs in the holes.
Saw Mill #1469975 10/06/2022 11:25 PM
Thank you for the information. I appreciate it.
1951 GMC 451
