| | | Forums66 Topics128,054 Posts1,055,780 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 83 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 83 | I have a '41 AK that the clutch, driveshaft/torque tube and rear end were rebuilt last year. They had a real problem with the driveshaft and a bushing in the torque tube. Had to have the machine shop get involved. Something about a bushing getting pressed out and a new one made and installed.l
Everything worked fine for awhile and then I started getting a "ratcheting" noise from driveline when slowing down. The shops both said was just a "self clearing" issue . That has got much better. Now I have a vibration in driveshaft at 45 mph and above. Doesn't sound or feel like a U-joint. Only happens at speed and goes away when below 45.
The shop/mechanic who did the work is not longer available to ask. Any suggestions ? I have already thought about not going above 45, but I put the 355 gears in to be able to cruise at 55. | | | | | Joined: Oct 2021 Posts: 6,762 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,762 | Get under the truck with the rear wheels raised and turn the driveshaft by hand and see if there is slop or slack in the U joint before the axle begins turning. Even a few thousandths of an inch of play can give you a vibration.
Try to move the shaft from side to side and see if the is any play at the U joint / yoke.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jul 2019 Posts: 83 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 83 | It has a torque tube. Can't turn driveshaft. you can feel it move when you turn wheels.
How much "free play" should there be when you move rear wheel before you feel drive shaft move?
Also, when I turn the wheels you can hear a soft ratcheting sound coming from driveshaft.
I don't know if I have no problem, small problem or a big issue. | | | | | Joined: May 2015 Posts: 11,040 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,040 | I think you'll have to remove the u-joint cover and inspect that. If the shop didn't refill the u-joint bell it may have already worn out. It's a bushing type u-joint (no needle bearings like modern u-joints) and relies on the transmission lubricant in the rear half of the transmission for lubrication. It's also possible that the shop didn't get a seal behind the new torque tube/shaft bushing installed correctly and the lubricant has drained out into the rear axle. You could pull the rear differential fill plug to see if it's overfilled. My money is on the u-joint being the problem. I'm also suspecting that the "self clearing" comment by the shops was just a way to blow you off.  Most noise issues don't fix themselves, especially ratcheting type noises. They usually get worse like yours has.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2019 Posts: 83 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 83 | Thanks, I am going to look at u=joint. The truck has a GMC 228 engine and a 4 speed. is the transmission the same on the GMC and Chev engines? | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | ronsway Better listen to klhansen,that ratchetting noise was probably the no rollers u-joint being killed by no lubrication. Is now loose enough to give vibration. Once had a farm truck dry tranny that squalled terible,went to drain it no oil,filled it waited overnite just fine the next day. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | The transmission for GMC and Chevy are the same.
As stated above, the u-joint ball needs about a pint of gear oil. It is often forgotten......
Question: If you drive over 45 to 55 does the noise go away or get louder???
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
