2 members (Hotrod Lincoln, mo2cyl), 380 guests, and 5 robots.
Topics128,158
Posts1,057,025
Members48,460
#1468889 09/29/2022 10:57 PM
Anyone got a picture or diagram showing the bracket that mounts the external parking brake band to a spicer 5 speed? Got a 59 chevy 2 1/2 ton that doesnt have one and trying to put one on. Any pictures in general would be helpful too.
59 chevy Spartan 100, former firetruck
348ci with spicer 5 speed and electric rear
MattMcK #1468907 09/30/2022 1:13 AM
What parts do you have?
Is the drum and output flange still on the back of the transmission?
Do you have the hand brake lever and it's linkage?
Post a picture of what you have...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #1468926 09/30/2022 9:43 AM
Since the truck was a firetruck, it had a parking brake behind the pump but that is long gone, so I am left with the lever and a super long rod. There are 3 mounting studs left on the drivers side of the trans where a normal brake would have gone. I got a band assembly from someone off a clark transmission i believe since its 9 1/2x2 1/2 instead of 9 1/2x3" but dont have the drum or attaching bracket yet.
Ill get some pictures this afternoon.
MattMcK #1468941 09/30/2022 12:23 PM
Crusing in the Passing Lane
That location is a good one for mounting a Brownie trans. if you wish an OD drive gear. Brownies come with park brakes.
Ed
MattMcK #1468950 09/30/2022 1:07 PM
If i had the original driveshafts, i would love to add a brownie but unfortunately its cut to fit without one. Maybe some day. Basically everything that touched a piece of fire equipment was cut off with a plasma cutter.
MattMcK #1469008 09/30/2022 7:52 PM
Heres what i have. There is a pto for the dump bed going in the open pto spot.
MattMcK #1469011 09/30/2022 8:47 PM
It is always best to start out an additional piece of driveline equipment with correct, known, new driveshafts.
Ed
MattMcK #1469018 09/30/2022 10:19 PM
The guy I bought the truck from took the driveshafts out of a schoolbus and had them cut to the correct length so they are relatively new.
MattMcK #1469055 10/01/2022 1:56 AM
Looks like you have everything for the passenger side of the trans, but your missing the Bar, Pin and Spring for the drivers side.
See if these pictures help...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
MattMcK #1469085 10/01/2022 11:13 AM
Where did you get that middle exploded view? Thats great, didnt see that in the shop or assembly manual.
MattMcK #1469178 10/02/2022 2:15 AM
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
MattMcK #1549955 06/18/2024 8:42 PM
Reviving this in my search for a drum. I made a post in parts wanted, but does anyone know if there is another transmission that has a parking brake drum that would fit my spicer 3152? At this point I dont care if it is narrower like the clark or wider like the spicer, I just need something!
MattMcK #1549958 06/18/2024 9:06 PM
look at see if the clark parts are interchangeable with spicer
if it does or maybe you can just use some of them
https://www.vanderhaags.com/detailv...e=transmission-brake&wcf=parentmodel
MattMcK #1549960 06/18/2024 9:11 PM
Looks like vanderhaags has some 3152 transmissions for sale with the brake on it. maybe they will just sell you the parts needed
hcb3200 #1550848 06/27/2024 9:05 PM
Anyone know what transmissions have the same parking brake? Are all the spicer 5 speeds the same? If there is a more common one, maybe i can search for that.
MattMcK #1550885 06/28/2024 2:40 AM
My parts books show Chevrolet only used one Spicer 5-speed from 1956-66. They all used the same Drum (Spicer 20B-54). You'll need to contact Dana/Spicer to see what other transmissions might have shared this drum. Drums from other manufactures won't have the same bolt pattern or drum center disc offset. You'll need to match your output shaft Flange bolt pattern with the Drum.
Call R L Jackson in Port Deposit, Maryland and see if they can help, they sell used truck parts...Phone: (410) 378-2481
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
