1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1468864 09/29/2022 9:04 PM
So I have never had the brackets for the running boards attached to the chassis and I'm wondering what the order is I assume the longest goes in the front followed by the medium length and the shortest on the rear of the chassis due to the chassis being tapered. Am I correct?
1952 GMC
Starting with a basket case
In the Project Journals
1967 GTO
1967 Firebird
I believe that's correct. I don't know if the repops have the same features, but they look different. There are lefts and rights also, but apparently only for the front bracket.
Just measured mine on my chassis. Front is ~18.5" frame to end, Center is ~17.5" and rear is ~15"
Thanks for measuring those. Yes I did notice that the fronts have a little bend on them so I need to determine which is right or left. They are not repops.
1952 GMC
1967 GTO
1967 Firebird
I just found an image in the assembly manual that I think I can determine which side is which for the front brackets
1952 GMC
1967 GTO
1967 Firebird
The front brackets have a bend that angles toward the back of the truck. Hold the mounting surface against the frame and you should be able to tell easily which is which.
