| | | Forums66 Topics128,022 Posts1,055,382 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2021 Posts: 174 'Bolter | | 'Bolter Joined: Aug 2021 Posts: 174 | So I have never had the brackets for the running boards attached to the chassis and I'm wondering what the order is I assume the longest goes in the front followed by the medium length and the shortest on the rear of the chassis due to the chassis being tapered. Am I correct? | | | | | Joined: May 2015 Posts: 11,001 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,001 | I believe that's correct. I don't know if the repops have the same features, but they look different. There are lefts and rights also, but apparently only for the front bracket.
Just measured mine on my chassis. Front is ~18.5" frame to end, Center is ~17.5" and rear is ~15"
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2021 Posts: 174 'Bolter | | 'Bolter Joined: Aug 2021 Posts: 174 | Thanks for measuring those. Yes I did notice that the fronts have a little bend on them so I need to determine which is right or left. They are not repops. | | | | | Joined: Aug 2021 Posts: 174 'Bolter | | 'Bolter Joined: Aug 2021 Posts: 174 | I just found an image in the assembly manual that I think I can determine which side is which for the front brackets | | | | | Joined: May 2015 Posts: 11,001 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,001 | The front brackets have a bend that angles toward the back of the truck. Hold the mounting surface against the frame and you should be able to tell easily which is which.
