3 members (j05h79, Phak1, Jay R), 73 guests, and 3 robots.
Topics128,154
Posts1,056,837
Members48,456
#146867 05/15/2006 6:56 PM
Y
Junior Member
Junior Member
Y Offline
I have tried the local shops and Jim Carter with no luck.I was also told that a trailor supply place would have them, but there aren't any in my remote area. If anyone has a part number that I can give the local yahoos to run maybe I can get what I need. The truck is done with the exception of these bolts and after two years of work I would like to drive her. Any help would be apprieciated.
1951 6400
1954 6100 dump
2 1962 IHC scouts
3B Offline
Hy yabica, if I'm reading my Jim Carter catalogue correctly the part you want is ME493 $29.95,hope that helps.
They are not hard to get, can even be had from spring shops.
I believe ones from a 1 ton through the 2 ton are the same.
•1952 Chevrolet 3800 pickup
---All pictures---
Y
Junior Member
Junior Member
Y Offline
They are on the way, thanks guys.
1951 6400
1954 6100 dump
2 1962 IHC scouts
