| | | Forums66 Topics128,161 Posts1,056,906 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 37 Junior Member | | Junior Member Joined: Oct 2005 Posts: 37 | I have tried the local shops and Jim Carter with no luck.I was also told that a trailor supply place would have them, but there aren't any in my remote area. If anyone has a part number that I can give the local yahoos to run maybe I can get what I need. The truck is done with the exception of these bolts and after two years of work I would like to drive her. Any help would be apprieciated.
1951 6400 1954 6100 dump 2 1962 IHC scouts
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy yabica, if I'm reading my Jim Carter catalogue correctly the part you want is ME493 $29.95,hope that helps. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | They are not hard to get, can even be had from spring shops. I believe ones from a 1 ton through the 2 ton are the same. | | | | | Joined: Oct 2005 Posts: 37 Junior Member | | Junior Member Joined: Oct 2005 Posts: 37 | They are on the way, thanks guys.
