8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible), 58 guests, and 1 robot.
Topics128,049
Posts1,055,699
#1460908 07/31/2022 5:59 PM
While attending a local car truck get together with Fox last Wednesday in Stony Plain I noticed a 72 longhorn 3/4 ton had parked beside me.
I’ve been handling out flyers for a couple of years looking for a replacement gear set for my 5:14. He mentioned he had a complete rearend out of a 1970 3/4 ton sitting in the grass behind his garage but wasn’t positive if it was what I was looking for, he said I could come out to see if it’s in fact a Eaton.
I’m happy to report that it’s a go to upgrade my 1950 1Ton.
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
doyle1950 #1460929 07/31/2022 9:17 PM
Nice score!
Got any photos of the Longhorn?
BC
1960 C60 pasture art
doyle1950 #1461376 08/04/2022 2:32 PM
Fox Offline
Now your 2-60 air conditioning will work, Doyle!
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
doyle1950 #1466649 09/16/2022 9:56 AM
62401
Yay! Gives hope to those still looking that they are still out there.
Thanks for sharing.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
doyle1950 #1466910 09/17/2022 4:24 PM
I'm looking to go the other direction- - - -lower gearing. Is there a lower ratio gearset than the 5.13:1 available for the 1 ton rear axle? I'm trying to decide what rear end to use on a doodlebug tractor I've got on the drawing board, and so far, I've got a choice between a 5.13 single speed axle and a vacuum shift 2 speed that can get down into the 8-something gear ratio on the low side. Power is going to be a Mercruiser 4 cylinder, with a turbo 350 automatic and a crash box 4 speed in tandem ahead of the drive axle.
doyle1950 #1466914 09/17/2022 4:53 PM
62401
Jerry -- An auto tranny in a Doodlebug???
headscratch
That's just .... wrong.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
doyle1950 #1466955 09/17/2022 8:17 PM
Yep, but with a crash box behind it! A torque converter effectively doubles engine torque for added pulling power from a stop- - - -then all the gears take over. The only thing that will keep it from climbing trees will be lack of traction!
doyle1950 #1468454 09/27/2022 11:38 AM
They must only be in canada eh? I couldn’t find one anywhere around me but I did get one from canada finally.
Barnfind49 #1468608 09/28/2022 12:04 AM
62401
chug
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
doyle1950 #1469089 10/01/2022 12:01 PM
I found mine in Canada also!
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
doyle1950 #1470335 10/09/2022 3:25 PM
Leo Offline
Moderator
Moderator
I brought three of those axles down to homecoming several years ago. Couldn't get the smile off Jim's face all weekend...
doyle1950 #1471639 10/19/2022 11:00 AM
And I am still, forever grateful, that my Northern friend, (Leo) was kind enough to go to the salvage yard, pick it up, place it in his van, drive it a couple hundred miles south, without hesitation!!
True friends for life!
thanks again Leo!! chug shake
Jim
In the DITY Gallery
Moderated by  Dusty53
