| | | Forums66 Topics128,087 Posts1,055,985 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14681 11/20/2003 1:47 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | A friend of mine has a 90 Chevy truck,he claims the 350 engine uses of quart of oil every 50-75 miles, gonna have to pull it. When he drove off I didn't see a cloud ,but just that puff of oil smoke typical of high mileage smallblocks, no big oil drops left behind either.I figured a quart every 50 miles is a real smoker, whats up? | | |
#14682 11/20/2003 2:06 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | tis strange, you would think with that type of use you could really tell what is wrong,, I had a 350 once that would use a quart about every 200 miles,, it did not smoke a lot but....Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#14683 11/20/2003 4:12 AM | Joined: Oct 2003 Posts: 70 Member | | Member Joined: Oct 2003 Posts: 70 | ASK THE SMOG GUY I HAVE SEEN LOTS OF BURNERS BUT NO SMOKE. THE ONLY THING I CAN FIGURE IS THE CAT GETS SO BLASTED HOT IT BURNS EVERYTHING. I WORKED AT ACHEV DEALER ONCE AND THE GM REP. SAID 1qt EVERY 250 MILES IS NOT EXCESSIVE YET, GO FIGURE | | |
#14684 11/20/2003 4:28 AM | Joined: Sep 2003 Posts: 55 Member | | Member Joined: Sep 2003 Posts: 55 | A couple of years ago I was on the freeway fallowing an older Chev. I started getting splashed by little drops. I turned the wipers on and smeared oil all over the window. I had to get off the freeway to clean it off. I think it was 50 wieght. Glad it wasn't raining. | | |
#14685 11/20/2003 2:55 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Burning that much oil you can smell. If not in that car, follow it around with your windows open in another. Have the guy stand on it a couple of times.
If the catalytic converter was burning that much oil it would get clogged in a matter of months.
Maybe it only leaks when running above idle. I would check the bottom of the car and look for signs of oil.
54 3100 with 235 62 flatbed dump C60 with 261
#14686 11/20/2003 3:05 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Tony M,that's the strange part, no smell, no oil leaks, not really much smoke.I took a ride with him in the truck, we went about 120 miles, and the truck used 2 quarts of oil.It runs quite well, good power and smooth, the oil pressure is normal.But I noticed the tail pipe tip is coated with black kinda dry soot, not the oily mess you would expect. | | |
#14687 11/20/2003 5:19 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | Could be valve guide & seal's, as those really do not affect performance of the motor, but will burn oil when bad. | | |
#14688 11/21/2003 2:18 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Did you check the PCV valve?
Fred 52 3600 69 C-10
