4 members (Oswald, treegrower, Nick in Manitou, 1 invisible), 40 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
I’m in the process of gathering parts to do a 5spd transmission conversion on my 1946 1/2 ton short wheel base Chevrolet. What drive shaft do I need?
Is there a std size drive shaft that will work, or do I have to get a custom drive shaft made?
Doing an early 60’s Chevy truck differential.
92 or earlier S-10 5spd trans.
Aftermarket 5spd adapter.
Short style throw out bearing.
Which drive shaft?
Care taker of a 1946 1/2 ton. Pretty much period correct original. Danny T, from B’ham, Al
Moderator, Electrical Bay
Don't know about the 1946 and likewise I don't have any idea what the junkyard situation in Birmingham is, but I had to have one made for me. All the ones I found were either an inch too short (won't work...yoke doesn't slide in quite enough) or too long. I could have cut a long one down, however all those I found had the wrong u-joint scheme and I never have liked those half/half u-joints made to connect the wrong thing to the right thing. At least the one I had made is completely balanced and uses proper u-joints. Good luck!
~ Jon
90% sure your going to have to get one made. You could hunt the salvage yards with a tape measure and calipers for days and not find one that fits. It’s been about 5 years since I had one built but the price was just at the $300 mark.
Lots of variables are at play here.
My situation is different but some of this might be useful info.
I have a 1963 C10 with 115” wheelbase. I found a salvage yard drive shaft that was the correct length and had the correct slip yoke. All I needed to do was swap out the rear universal joint for a conversion u-joint and it bolted right up. Drives great and without vibration.
My 1965 C10 also has the 115” wheelbase but I had a driveshaft shop swap modify my original driveshaft. They swapped out my original slip yoke for a correct slip yoke from an S10 truck. That required a conversion u-joint for the slip yoke. The rear u-joint did not need to change. They shortened the driveshaft about 3”.
Dennys Driveshafts has a website and a free worksheet that can help you measure the correct length driveshaft for your application.
The pictures below show the salvage yard Blazer driveshaft I used in my 1963. Neither of my trucks have an adapter plate for the T5. The conversion u-joint pictured was correct for my application but might not be correct for yours. The Blazer slip yoke pictured is correct for a T5.
