6 members (3800GUY, David Bush, Oswald, Wally / Montana, Rusty Heaps, 1 invisible), 34 guests, and 2 robots.
Topics128,074
Posts1,055,911
Members48,429
#14681 11/20/2003 1:47 AM
A friend of mine has a 90 Chevy truck,he claims the 350 engine uses of quart of oil every 50-75 miles, gonna have to pull it. When he drove off I didn't see a cloud ,but just that puff of oil smoke typical of high mileage smallblocks, no big oil drops left behind either.I figured a quart every 50 miles is a real smoker, whats up?
#14682 11/20/2003 2:06 AM
tis strange, you would think with that type of use you could really tell what is wrong,, I had a 350 once that would use a quart about every 200 miles,, it did not smoke a lot but....Fred
Redryder pix
My Hotrod
#14683 11/20/2003 4:12 AM
ASK THE SMOG GUY
I HAVE SEEN LOTS OF BURNERS BUT NO SMOKE.
THE ONLY THING I CAN FIGURE IS THE CAT GETS SO BLASTED HOT IT BURNS EVERYTHING.
I WORKED AT ACHEV DEALER ONCE AND THE GM REP. SAID 1qt EVERY 250 MILES IS NOT EXCESSIVE YET, GO FIGURE
#14684 11/20/2003 4:28 AM
A couple of years ago I was on the freeway fallowing an older Chev. I started getting splashed by little drops. I turned the wipers on and smeared oil all over the window. I had to get off the freeway to clean it off. I think it was 50 wieght. Glad it wasn't raining.
#14685 11/20/2003 2:55 PM
Burning that much oil you can smell. If not in that car, follow it around with your windows open in another. Have the guy stand on it a couple of times.
If the catalytic converter was burning that much oil it would get clogged in a matter of months.
Maybe it only leaks when running above idle. I would check the bottom of the car and look for signs of oil.
54 3100 with 235
62 flatbed dump C60 with 261
#14686 11/20/2003 3:05 PM
Tony M,that's the strange part, no smell, no oil leaks, not really much smoke.I took a ride with him in the truck, we went about 120 miles, and the truck used 2 quarts of oil.It runs quite well, good power and smooth, the oil pressure is normal.But I noticed the tail pipe tip is coated with black kinda dry soot, not the oily mess you would expect.
#14687 11/20/2003 5:19 PM
Could be valve guide & seal's, as those really do not affect performance of the motor, but will burn oil when bad.
#14688 11/21/2003 2:18 AM
Did you check the PCV valve?
Fred
52 3600
69 C-10
