Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (carbking), 141 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#1468183 09/26/2022 12:43 AM
Any hints on how to shim, tighten, replace tailgate hinge/pivot on a ‘57 3200?
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
Fox Offline
If it isn’t painted, remove the tailgate and tap the topside of the tailgate pivot pocket (on the tailgate), effectively giving it a slight egg shape. It tightened up my reproduction’s slop. Very little is needed.
If it’s old and sacked out, you could try the above, or break out the mig and weld a couple tack welds on the tailgate pocket. Die grind to fit/taste.
Being that it’s a 57, if the box pivot is worn, it should be split (IIRC) on the bottom side and you might be able to drive a wedge in the bottom expanding it slightly to a size that is tight. My 70 C10 pivot has no split along its bottom edge.
Good luck.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Man, if that's the biggest problem you have with you're truck, you're on easy street!
1950 Chevrolet 3100 (Ol' Roy)
