0 members (),
95
0
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2019 Posts: 251 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 251 | Any hints on how to shim, tighten, replace tailgate hinge/pivot on a ‘57 3200?
1957 Chevy 3200Daily DriverPS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights. Follow in the DITY | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | If it isn’t painted, remove the tailgate and tap the topside of the tailgate pivot pocket (on the tailgate), effectively giving it a slight egg shape. It tightened up my reproduction’s slop. Very little is needed.
If it’s old and sacked out, you could try the above, or break out the mig and weld a couple tack welds on the tailgate pocket. Die grind to fit/taste.
Being that it’s a 57, if the box pivot is worn, it should be split (IIRC) on the bottom side and you might be able to drive a wedge in the bottom expanding it slightly to a size that is tight. My 70 C10 pivot has no split along its bottom edge.
Good luck.
| | | | | Joined: Oct 2021 Posts: 7,032 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,032 | Man, if that's the biggest problem you have with you're truck, you're on easy street!
1950 Chevrolet 3100 (Ol' Roy)
