3 members (Hanks custodian, Steelonsteel, 1 invisible), 58 guests, and 0 robots.
Topics128,054
Posts1,055,780
I have read and reread the shop manual and the devestechnet article. I am now trying to remove the pinion gear and drive shaft. The entire rear and torque tube are out and on a bench. I have removed the trans trunnion bearing yoke as well as the 3 driveshaft locking bolts from the differential housing at the rear.
I am under the impression that the pinion gear and full drive shaft should now pull out rearward. I have tried all sorts of leverage at the pinion gear as noted in the devestechnet article. Can the shaft and pinion gear be driven out by striking the transmission end of the driveshaft? Is there a puller that can be used on the pinion gear in the diff housing?
Any and all experience and input is greatly appreciated
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
The 48-51 shop manual says after removing the bearing retaining screws from the differential housing, "tap the splined end of the propeller shaft allowing the pinion shaft to slide out."
The 1/2 ton torque tube axles were pretty much the same up thru 55, with only minor changes. So you should be able to drive the shaft out from the transmission end. I would use something relatively soft (a soft faced hammer or wood block) to prevent damaging the splines.
I recently removed the pinion gear and shaft from a ‘46 due to a couple of chipped teeth. I did have to use a block of wood and a heavy hammer to knock it out of the tube. It also had the Oakie bushing installed too which I am sure contributed to the resistance. I hope this helps.
I invest my money in precious metals, mostly rust!
Thanks folks. Oakie bushing! Yes getting that out might help.
Once all the setscrews are removed, a block of hardwood and a BFH or a splitting maul should get it moving. It's probably stuck pretty tight after being there for several decades. You might also consider heating the housing where the setscrews are located and maybe squirting some penetrating oil like PB Blaster through the holes.
Well. The wood and BFH did the trick. Thanks gents.
