| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 48 | Hey. I just bought a 48 or 49 6400 on ebay. What an adventure. It runs but needs brake work. When I pulled the rear drum I found that the surface for the axle oil seal was damaged. It looks like someone may have welded on it, then ground it down. Not pretty! I have tried the local places around Tulsa for a repair sleeve. No luck. Surely someone else has had this problem. Also the data plate is missing. I bought the truck on bill of sale with no no title. Any ideas? | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Hey Dave,Are you sure the damage is were the seal rides ? Most of the time the damage is done were the inner bearing race rides.The bearing locks due to low axle oil and spins on the housing doing damage.If it IS just in the seal area,get a new seal and see how well it fits on the housing(just push it on without the hub).Use emery paper to dress up the housing.As for the data tag,I have only seen the lower GVW(3100,3800) ones available.Hope this helps.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
