2 members (Bill Hanlon, Rich'sToys), 82 guests, and 2 robots.
Topics128,127
Posts1,056,678
Members48,452
Working on getting the gas gauge and sending unit to work well together. So I have purchased the HD Voltage reducer from Jim Carter parts. My questions is where did you locate yours? Did you put it up under /behind the dash or by the sending unit in the Tank? Any and all opinions will be appreciated. Thanks in advance!
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Curmudgeon
Curmudgeon
Your profile says you have a 49 1/2 ton.
A voltage reducer to drop the voltage from 12 volts to 6 volts, I assume?
The reducer that JC sells for the fuel gauge part # EL110 "light duty" is 22 ohm, 10 watts.
The reducer that JC sells as part # EL135 "heavy duty" is 50 ohm, 50 watts.
If you purchased the EL110 then instructions says, "Attaches to positive wire that leads to fuel gauge."
JC is short on details but the other end (lead) of the resistor would connect to the fuel gauge.
