Here's where it started with a post by Tim Lederman in the Driveline forum. From there, the Stovebolt Collective rolled in.
I see that there is now a 200 Private Message limit. I am way over the limit.
I do not see a way to delete old messages - you get to delete all or none. I would like to keep the most recent 100 messages. Until I figure out how to do that, I will not be able to receive private messages.
At one point, Tim had 10,000 PMs. After a few swipes, using Rustoholic guidance below, he got it to a manageable 1400. Then he went for the gusto, realizing they were mostly old news by that time.
So, read on and see.
Tim, click on your envelope. This should show all your PMs. On the far right side of the page you can select by clicking the small box without opening the PM. Scroll down clicking/selecting the boxes as you go. When done selecting, click on “Delete Selected” and all PMs you checked will go away. No need to do one at a time, unless you want to read them before deleting.
Instead of individually selecting the ones you want to delete, use the select all button, then unselect the ones you want to keep, then hit delete selected. That would take a lot less time than selecting 10 pages at a time.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
