5 members (Wally / Montana, DadsFirstPickup, Leo, CATMAN, rfs56trk), 138 guests, and 3 robots.
Topics128,162
Posts1,056,951
Members48,458
Hi I'm new to the site. Looks like I can get some good info here. I am converting the stock 3 speed to a 4 speed (sm420). I have a 49 3100 with the torque tube which I want to keep. I noticed that the size of the output shaft on the 3 speed is 1' and the 4 speed is 1-3/8'. Is there a tranny side u-joint yoke that adapts to the torque tube side? I would very much appriciate any info on this.
Rick
Curmudgeon
Curmudgeon
Thank you for the info. This opened up a whole new world
Rick
Curmudgeon
Curmudgeon
1 Offline
One of the reasons that the "bell" on the end of the SM420s is hard to find is that they tended to break from the torque reaction of compound low or reverse. On the 3/4 tons I've seen, the drive line is a hybrid: enclosed from transmission to carrier bearing mounted to a cross member and open from there back. These didn't break the end housing.
In my younger days, these pickups were still in common use and the country half tons were often used far beyond their intended limits. Most of the town or city half tons were probably three speeds and the country half tons were mostly four speeds. A friend of mine back in the day used his 51 half-ton for hauling water when the well went dry - a 325 gal oil tank, hopefully never used for heating oil. He did that till the frame cracked. After that, we used my 1-ton with the same tank. I was sharing a farm house with him.
He got the frame welded up and that winter, hauling firewood out of the woods with chains on, he cracked the bell on the back of the transmission.
1951 3800 1-ton
In the DITY Gallery
Yeah that would be about 1900 miles for me. Thank you though for sharing that.
Rick
Great story and good info. Thank you.
Rick
rustyrico,
Check your PMs. thumbs_up
~ Dan
1951 Chevy 3 window 3100
