7 members (TUTS 59, Gray_Ghost, panic, tclederman, Peggy M, MRMEROTH11, Wickedbass), 122 guests, and 0 robots.
Topics128,068
Posts1,055,880
Members48,428
#1465918 09/10/2022 4:26 PM
So... my little 270 has a zenith. What's a decent carter or Rochester carb that can be used? One mechanic said a Carter Y. I noticed the Carter has the closest set up style as the Zenith. Thanks.
now...where did that part go??
1 Offline
You can send your take-off Zenith to me. I'll pay the postage.
1951 3800 1-ton
In the DITY Gallery
Moderator, Electrical Bay
Well, there are Carter YF models made for the Ford 300 that might be good. The Carter YF3211S was the final carburetor made for the 235 and is a very good one (auto choke) and possibly the other Jon (CarbKing) may show up with some other suggestions. Honestly, your Zenith might be the best option, however. I'll bet large that Jon (CarbKing) has a rebuild kit for it and can help you get it back on the right path. You don't want a Rochester for it. Really hard to find one made for the 261 that hasn't been buggered like crazy and the Rochesters had some fundamental flaws that with today's gas make it worse.
~ Jon
GMC used Zenith carbs for a reason, they were better than the Rochester model 'B' built by G.M.
The model 'B' that would be best: '63 - '67 from a 292. There is one that comes up on Portland cl from time to time, has a tag, comes with manifolds. I inquired about it awhile back, would only sell as unit, I didn't want it bad enough pay shipping.
BC
1960 C60 pasture art
back yard wrench turner
I converted to a Weber 32/38 in place of the Zenith on my 270. It runs decent but will stumble at higher rpms. I think the fuel pump can't keep up at the higher revs.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Curmudgeon
Curmudgeon
We need more information...please.
For goodness sake if you have or had an original running engine and Hydramatic transmission, don't make changes now. It's like putting the cart before the horse. The absolute best carburetor is the one that came with the engine-transmission combination. I skimmed your past postings and didn't see anything about what you have other that a 1954 GMC plus your handle includes Hydramatic. I hope you took pictures and made notes of the shifter and throttle linkages before you pulled the engine. It will be agonizing to get it right again. Very few here can help guide you to get "Humpty-Dumpty" back together again and working correctly. If you plan to use another type transmission then please forgive my panic-ranting.
Carburetion specialist
If you have an automatic transmission; would be best to rebuild the original Zenith (opinion).
Jon
The Carburetor Shop
