0 members (), 52 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#1457560 07/05/2022 4:34 PM
My 1969 Chevy C10 has just the "three" opening bezel. I have a new bezel with all 7 openings, and have adapted the insides to accept a center tach, oil, ammeter, and temp gauges which will be wired separately from my original circuit cluster.
Question is, can I just remove the brake and temp idiot light bulbs in order to eliminate these from the circuit without harm? I am using the original circuit cluster.
Taking the bulbs out won't hurt the truck. Mark the sockets in case the next guy needs to know.
If you have an alternator warning light and you remove it, your alternator may not work afterwards.
~ Dave
One is for brake the other for temp. I'm hooking up an ammeter for the alternator.
Thanks Dave. Already marked, but physically self explanatory.
Do be careful when leaving bulbs out of a socket, be sure to wrap or otherwise protect that/those potentially hot wires, if they get power and touch something (grounds out) it can easily let the smoke out of the entire wiring system….
To take this further…when installing a wiring harness do not hot it up without a bulb in every single socket
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
This is a printed circuit, no wires, and the bulbs are in parallel, so you can have a bulb out without affecting the other bulbs.
So far so good. Got the ammeter tested and working. Tach works. Have new electrical sensors for oil pressure and water temp. Just have to drain oil and water to install sensors, then test. Waiting for new printed circuit as the directional indicators are moved out from the tach installation. Might take awhile, but I will keep you posted.
Ammeter, temp, oil pressure, tach, all tested and working. Received my new circuit cluster. Now just waiting to get my truck back! In between all this I did some work on the exhaust and ended up twisting an exhaust manifold bolt off. Come to find out, the exhaust manifold was warped and leakiing (who knew, the truck was running just fine), so now waiting to receive a new exhaust manifold. One thing leads to another...but then it all comes together.
Just a note for future conversions. When you switch your bezel from 3 window to 7 gauge windows and new circuit cluster, you must move the wires on the plug in the back that goes into the new circuit cluster. The connections are not the same for all circuit clusters. Found this out the hard way after putting it all back together.
