1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1465665 09/08/2022 5:24 PM
I have not attempted to disassemble this rim yet. I am pretty new to this, but from what I can tell it is a 3 piece rim? Looks like it was manufactured by Kelsey-Hayes. If it is a 3 piece, what are the collective thoughts of the group on staying with the 3 piece rim compared to upgrading to a modern one piece rim?[img]https://cdn.shopify.com/s/files/1/0084/2468/5639/files/IMG_8778.jpg?v=1662657815[/img][img]https://cdn.shopify.com/s/files/1/0084/2468/5639/files/IMG_8779.jpg?v=1662657818[/img]
1954 Chevy 4400
2021 Mimaki JFX200-2513EX
Search this web site as there is tons of reading on this subject as this topic has been discussed here every month for decades...they never made a 22.5" one piece rim that is an exact match to your 10-lug bolt pattern with a 4.75" center hole.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Crusing in the Passing Lane
Hub ID on those is 5.250” starting in ‘56. Spacer easily made.
Ed
birchandboulder My 51 6400 has 3-piece wheels like that,several years back on the farm they put new rubber all around. Today it's still about 85% looks good runs good the trouble is the wheels may rust from the inside out,wont know till you take em apart. Mine have some weather cracking not much about 20 yrs old. Have learned that if they say nylon will hump worse after sitting and last better even if they don't look so good cause the nylon wont rot out. To answer your question keep those wheels for looks and cause they're cheap and the truck tire shops will work em. However don't trust a 70 yr. old wheel,chain it, cage it,clip-on air hose from a distance, just don't take chances with it.
Mike B #1465768 09/09/2022 12:16 PM
I searched the topic, however, the search function is sort of 3rd world-ish. Hard to find the 7.5-20 tires currently, seems like 8.25-20 are available, but I think the rim may be too narrow.
1954 Chevy 4400
8.25 were optional on the 6" rims, 6.5x20 and 7.0x20 used a 5".
Power King Super Traction HD and Super Highway HD used to be available.
The Powerking tires seem to be out of stock everywhere. It currently has 7.50-20 on the rims, got my bead breaker in today and got one torn apart. Has the 6” rims on it, so might go to 8.25-20 if I can find them.
1954 Chevy 4400
8.25 might be all you can get anymore, another thread has rumors of 7.5 being available easy.
