5 members (rfs56trk, Gib70, Lightholder's Dad, Gray_Ghost, 1 invisible), 134 guests, and 1 robot.
Topics128,080
Posts1,056,060
Members48,433
#1465068 09/03/2022 10:38 PM
Can you replace the stock 4spd with a 3spd? Any other changes required for the swap? Are they a direct replacement?
Care taker of a 1946 1/2 ton. Pretty much period correct original. Danny T, from B’ham, Al
Dltalfa #1465069 09/03/2022 10:40 PM
This is on a 1946 with a 1952 235 6cyl engine.
Dltalfa #1465071 09/03/2022 10:43 PM
What vehicle, and what year? It's a giant leap backwards, but with enough time, money, and effort, it can be done. If you decide to dispose of the 4 speed, I want it! I might even be persuaded to trade you a 3 speed for it. No, I won't install it for you!
It’s a 1946 Chev with a 1952 235 6cyl. Currently has the non-synchronized “granny low” 4spd.
Why do you say it would be a giant leap backwards?
Dltalfa #1465076 09/03/2022 11:12 PM
Really! Going with a 3 speed is a good anti theft gesture.
Craig
Dltalfa #1465096 09/04/2022 3:39 AM
Curmudgeon
Curmudgeon
Taking cues from the sparse information provided, a terse reply:
1965 and later Saginaw 3-speed transmission had synchronized first gear.
It and the correct bell housing will fit the 235 but the transmission output is open drive (not torque tube).
There are 1st gear ratio options but final gear is 1:1. This you need to know to work with your current rear axle ratio.
To avoid calamity of a modified 3-on-the-tree setup, you would want a Hurst truck floor shifter, modified bracket and linkage. You have to make a new hole in floorboard.
Others will come along and give recommendations on the T5 5-speed transmission from an S10 but you specifically stated a 3 speed transmission of unknown year or make.
Dltalfa #1465098 09/04/2022 3:54 AM
I missed the crash box info. You can swap the bellhousing for a 1948-53 unit and use either the truck 3 speed or a SM-420 4 speed to get some of the gears synchronized. Swapping the crossmember at the cowling for a 1954-up item and converting to an open driveline and a different rear axle will give you more options on transmissions, including the T-5 which is a fully synchronized overdrive 5 speed. Basically, everything from the bellhousing on back will probably have to be swapped- - - -nothing is a direct bolt-in fit.
buoymaker #1465103 09/04/2022 11:13 AM
. I apologize, but I clearly confused everyone. I am asking can I change the 1946 4spd for a 1946 3spd directly. I’m not asking about going to a more modern drive train. The current 1946 4spd with the “granny low” 1st gear is a total non-synchronized transmission….on all 4 gears. The 1946 era 3spd transmission is geared higher and is synchronized on 2nd and 3rd. I’m asking can I go to an original era 3spd without any modifications. Is it a direct fit?
Dltalfa #1465108 09/04/2022 12:37 PM
Crusing in the Passing Lane
‘46 three speed may be ‘geared higher’ in first two gears, not in direct!
Ed
Dltalfa #1465110 09/04/2022 12:42 PM
Dltalfa #1465113 09/04/2022 1:16 PM
Dltalfa,
Spent a few minutes researching your clarified question using the resource provided for all at http://chevy.oldcarmanualproject.com/index.htm (all credit to them for sharing this valuable resource thumbs_up ).
Comparing the following pages from the 1941 Car and Truck Shop Manual (also covers through 1946 models as basically few changes during the war years), it does not appear that a truck 3 speed would be a direct bolt in for the truck 4 speed.
http://chevy.oldcarmanualproject.com/shop/1941/41csm208.htm
http://chevy.oldcarmanualproject.com/shop/1941/41csm215.htm
3 speed truck trans (with top mounted shifter/not car trans with side mounted shifter arms) diagram displays output is for a torque tube enclosed drive and 4 speed shows output for an open style drive shaft.
Just info found using the original shop manual (I have limited personal experience with this era of truck) and am sure that others with more direct knowledge will chime in to help answer your question.
Hope this helps the conversation along. grin
Dan wave
~ Dan
1951 Chevy 3 window 3100
Dltalfa #1465114 09/04/2022 1:18 PM
The only modification will be to the pedal /master cylinder mount. Being that the four speed is wider, you will need to shim with washers between the mount and three speed to make up the difference.
As you can see from this list they are the same length.
My Blog
Dltalfa #1465245 09/05/2022 4:27 PM
24601
Wouldn't learning how to double clutch be easier??
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Dltalfa #1465339 09/06/2022 3:08 AM
Right!
Ed
Dltalfa #1465495 09/07/2022 2:37 PM
I was needing to double clutch my 4-speed but I found that pausing in neutral for an instant while keeping the pedal depressed before completing the shift worked. No grinding. And since I'm depressing the pedal only once, my knee will last twice as long.
My 3 on tree is the same way. Alitta pause goes along way.
