| | | Forums66 Topics128,013 Posts1,055,322 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2022 Posts: 162 'Bolter | | 'Bolter Joined: Feb 2022 Posts: 162 | What kind of aftermarket fan fits a 216 motor? Other than electric.
1953 with a 216
| | | | | Joined: Feb 2004 Posts: 29,744 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,744 | Measure the center hole Measure the bolt spacing Measure the diameter of the blades Measure the depth of the blades Buy something that fits Problem solved! Jerry
| | | | | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 |
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | What is wrong with the stock fan?
1950 Chevy 3100
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | A bit noisy, especially with truck gearing Wastes gas at speed (compared to better design or electric) | | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | Gotcha... I run my stock fan. Noise is minimal. As far as M.P.G. it's not bad . Being a 3 speed with original rear gearing. I just like the original look I guess.
1950 Chevy 3100
| | | | | Joined: Jun 2021 Posts: 157 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 157 | I have a Flex-a-lite - painted it black, so it looks more stock. Quite happy with it since years. Cools better than the original and draws less power at higher rpm. Only drawback is, you need a spacer. | | |
