4 members (Joe H, baldeagle, panic, 1 invisible), 74 guests, and 4 robots.
Topics128,014
Posts1,055,330
Members48,419
#1464586 08/30/2022 7:36 PM
What kind of aftermarket fan fits a 216 motor? Other than electric.
1953 with a 216
Luray #1464591 08/30/2022 8:04 PM
Measure the center hole
Measure the bolt spacing
Measure the diameter of the blades
Measure the depth of the blades
Buy something that fits
Problem solved!
Luray #1464594 08/30/2022 8:42 PM
Insomniac
Insomniac
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Luray #1465073 09/03/2022 10:57 PM
What is wrong with the stock fan?
1950 Chevy 3100
Luray #1465074 09/03/2022 11:04 PM
P Online: Content
A bit noisy, especially with truck gearing
Wastes gas at speed (compared to better design or electric)
Luray #1465079 09/03/2022 11:24 PM
Gotcha...
I run my stock fan. Noise is minimal.
As far as M.P.G. it's not bad . Being a 3 speed with original rear gearing. I just like the original look I guess.
1950 Chevy 3100
Luray #1465168 09/04/2022 10:13 PM
I have a Flex-a-lite - painted it black, so it looks more stock. Quite happy with it since years.
Cools better than the original and draws less power at higher rpm. Only drawback is, you need a spacer.
