2 members (Hotrod Lincoln, Hush), 58 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#1465032 09/03/2022 3:38 PM
Hello , got a 216 rebuilt motor. Installed flywheel and clutch, getting ready to install starter which is the correct position that it should be in stalled, I see the b.b.and triangle?
1953 with a 216
Luray #1465033 09/03/2022 3:59 PM
H Online: Content
Those marks have nothing to do with installing the starter. They are for setting the ignition timing, using the small window above the starter with the pointer in the middle of it. Align the BB with the pointer with the engine stopped, and turn the distributor housing counterclockwise so the points are just barely open. The timing can be set with either #1 or #6 cylinder in the firing position.
Luray #1465042 09/03/2022 5:54 PM
Yep, just bolt the starter on. It will engage the flywheel gears anywhere around it. It shouldn't even be engaged with the flywheel teeth unless powered on and spinning.
