| | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 20 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 20 | Can the harmonic balancer from a 1941 - 216 be used on a 1961 - 235? I'm swapping the 216 for the 235 and want to be able to keep the wide belt to appear as nearly stock as possible. I'm using the 216 valve cover. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | The balancer will fit, but the position of the water pump on the newer engine cannot be hidden, even with Dave's relocation adapter and the 216 water pump. Ray Charles could "see" the difference! What do you plan to do about the pushrod cover height difference?
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | They used different dampers for a reason, begining in this case with different stroke lengths. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Inline sixes are inherently balanced, so the "different stroke" idea doesn't hold water. 235's from 1941 to 1953 ran the same balancer as a 216. Six cylinders including 216, 235, 194, 230, and 250 all have the same diameter crankshaft snout (1 1/4") as well as most small block Chevy V8's. All the balancers for those engines will press fit onto a stovebolt crankshaft, but they won't necessarily have belt grooves that line up properly. Some have bolt-on pulleys. Jerry
| | | | | Joined: Oct 2015 Posts: 20 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 20 | Well, some things will just hafta look non-stock as in the case of the push rod cover. I'm a pragmatic idealist - everything should be perfect, but it ain't. There will also be a split exhaust and a dual carb intake. You might ask, then, "Why do you want it to be as close to original as possible?" I've asked myself that question already and can't answer myself. At my age and with south Georgia heat this is a slow process, so some things will probably change. Anyway, I really do appreciate your advice - it answers my question.
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | I can offer a few suggestions by private message if you like. I've done a considerable amount of experimentation on stovebolt balancers, and I might be able to offer an alternative to a 70 year old item that would allow you to run a wide belt with a newer part. Jerry
