0 members (), 122 guests, and 3 robots.
Topics128,271
Posts1,058,314
Members48,485
#1464568 08/30/2022 5:06 PM
Are you guys using a gasket or anything else for the top grill bar? My top grill bar touches the fender and I’m wondering if it’s going to wear through the paint over time. I tried to put some black sticky rubber under it but it looked pretty bad.
1950 Chevy 3100
Jason
1950 3100
50shep #1464571 08/30/2022 5:18 PM
Like all aftermarket metal parts, you need to modify those to avoid contact. That top bar can be moved around more easily than the ones below it. If loosening the fasteners doesn't work, you can make the screw hole bigger to allow more range of movement. If that doesn't solve it, you can bend the bar out away from the painted surface.
50shep #1464574 08/30/2022 5:26 PM
Probably couldn't hurt if you put some thin material in there. But, how long will it last?
50shep #1464582 08/30/2022 7:03 PM
You're right. A bit more finagling is required. Its close. Thank you.
1950 Chevy 3100
Jason
1950 3100
