| | | Forums66 Topics128,036 Posts1,055,454 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2022 Posts: 557 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 557 | What sparkplug wires are recommended for a 54 3100 without radio etc. No need for resistor wires. Historically, I just made wires from a roll of alum spark plug wire. Worked at the time. Suggestions? Have built a 235 from a 57 Nomad.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Metal core wires cause the carbon center button in the distributor cap and the tip of the rotor to erode rapidly. As long as you don't mind changing the cap and rotor at every tuneup, run whatever floats your boat. Jerry
| | | | | Joined: Jun 2022 Posts: 557 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 557 | Jerry... what would you use?
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | I've been using string-core resistance wires for 50+ years, even on 700+ HP round track racing engines. The idea that high performance or antique engines need metal-core wires is a myth. Jerry
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | That's interesting. Never really thought about it before.
The Internet says a typical modern spark plug has around 500 to 3000 ohms. 500 ohms new and increases as it ages. Modern spark plug wires have between 10,000 to 12,000 ohms (typically). A solid copper or aluminum core wire would have a few ohms or less. So a lot less resistance (500 ohms versus 10,500 ohms for example) means a lot higher current through the parts along it's pathway. It takes voltage to fire a spark plug (around 3000 volts). It takes voltage to jump the gap from the rotor button to each cap electrode. So the increased current (more than needed) would negatively affect the parts that move and parts that arc, more than the others. The other parts would have to dissipate more heat.
I think Jerry's statement has some merit.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | As with a lot of other automotive electrical system situations, firing a spark plug is not a simple resistive circuit with constant current flow. To initially ionize the gap(s) at the rotor and the spark plus electrode and get the arc flowing, a voltage of somewhere around 7-10 KV is required. Wide plug gaps, rounded electrodes, and loose or corroded connections need more voltage. Once the arc is established, that voltage drops considerably, down to the 3-5 KV range. This current flow continues at the lower voltage until enough of the induced voltage in the coil secondary is lost that the arc cannot be maintained any longer. Then the residual voltage left in the plug wire bounces back and forth from the plug terminal to the distributor cap, losing a few volts at each oscillation. A resistance wire can have up to 1K ohm per inch, which dissipates the residual voltage more quickly, preparing the conductor for the next firing impulse. Since a spark plug fires approximately 60 times per second at 2K RPM, getting rid of that voltage ripple quickly actually makes a resistance wire more efficient than a metal core, plus the current flow is reduced and parts last longer. That "hot blue spark" we used to look for was actually pretty destructive. Resistance wires produce a yellow/orange color spark that lights off the gasoline in the cylinder just as efficiently. Jerry
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Jerry as usual, you are spot on with your advice. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jun 2022 Posts: 557 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 557 | Thanks, Jerry... guess I'll use the metal core wires on the Johnny Poppers and get good resistor ones for the 235.
