7 members (LAJones48, Barry Martak, Otto Skorzeny, Waveski, Shaffer's1950, Rusty Heaps, 1 invisible),
110
Mod | | | Forums66 Topics128,094 Posts1,056,465 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2022 Posts: 37 'Bolter | | 'Bolter Joined: Mar 2022 Posts: 37 | i recently got my 6400 going again after i had to use the fuel pump in my nova, and i'd forgot about the clutch issues i was having, and it seems to have gotten worse. the pedal has almost no feel, like the diaphragm is shot. unfortunately, i understand that this is a 9 bolt diaphragm, which cannot be sourced newly. what are my options? at some point i want to put a 3-53 that my grandpa has in it (gama goat motor) but i won't be able to bring that motor from NY to NE until next summer, and i need to haul a lot of dirt with this truck between now and then, and i really don't want to have to throw a bunch of cash into something i'm going to be upgrading next year. is there a cheap way to get this thing working for a little while? thanks for any and all help. | | | | | Joined: Feb 2016 Posts: 1,990 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,990 | When I first acquired my '57 LCF the clutch was working poorly. As I moved it around the yard under its own power the clutch progressively worsened. It then froze in a spot between engaged and disengaged and I could no longer move the truck under its own power. Pulled the inspection cover to find the entire clutch cavity filled with mouse nest and the throw-out bearing rusted tight on the input snout. Pulled the engine and tranny and put in a new clutch, mine was easy to match 'cuz it's a '57 with a 283.
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | There are shops who can rebuild your existing clutch and pressure plate. That is what I did on my '50 Chevy COE. Check out BG&S transmissions in Grand Island or maybe places in Omaha. Kent | | | | | Joined: Mar 2022 Posts: 37 'Bolter | | 'Bolter Joined: Mar 2022 Posts: 37 | i think i've found a parts truck with a later 235 and sm420, i may get that and put the drivetrain from it in temporarily, as it has several other things that i want as well. but thanks for the tip, ill talk to a trans shop. sure is a pain finding parts for these old hunks of iron, but they are so much fun when they work. | | |
