0 members (), 136 guests, and 3 robots.
Topics128,193
Posts1,057,259
Members48,466
I have a 1952 one ton truck will the hubs inner change with a 1 1/2 ton. The brake drums on the 1 1/2 ton from a glence seem to be the same as the one ton except the lug count. The lug count or how wide it is dosen't matter to me as I have a fQrd rearend in my doodlebug just wourding if it woul work on my one ton spindels.
don't think so, between the 1 and 1 1/2 ton is the difference between light and med. duty trucks.
Keith
If it were easy they'd have grade schoolers doing it!
You might look at swapping the entire front axle.
Also what 1-1/2 is it? According to the restoration material the difference between a 3800 (1-ton) and a 4100 (1-1/2 ton short wheelbase) is not as great as with a 4400.
don't know if it helps, but I have a 1 ton and a 2 ton, the axles are very different in size of the I-beam.
•1952 Chevrolet 3800 pickup
---All pictures---
I'm not sure this is a 1 1/2 ton but it does have 10 bolt wheels. The front end measures out the same as my one ton for spring mounts and overall width. The brake drums are bigger than the 1 ton I may just change out the whole front end. Thanks for the help.
Tony
it is either a 1.5 ton or a 2 ton with the big 5 and 10 lug pattern. the fronts do measure the same, and can be interchanged as an entire unit.
---All pictures---
