| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2022 Posts: 19 'Bolter | | 'Bolter Joined: Aug 2022 Posts: 19 | Hello All,
First post and question: I have removed and completely disassembled my 591102 transmission from my '41 pickup. No search has shown much about this specific casing. The only info I have on it is that is a 1940 model used in pickups and is similar(?) to passenger car models. Rebuild parts ordered hoping that gaskets, thrust washers, etc. are correct. Any direction towards rebuild on website, book, and/or video would be helpful. I've done a couple of Borg-Warner T5's in the past but had excellent videos. Thanks... | | | | | Joined: Aug 2003 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 108 | I just did a '46 car 3 speed. I believe they are the same for 40 through 53 (torque tube applications). I found the following videos very helpful, along with the shop manual:
youtu.be/E-tgWVIILdQ
youtu.be/V5qW43H51Ks
Good luck, and let us know how it goes!
| | | | | Joined: Aug 2022 Posts: 19 'Bolter | | 'Bolter Joined: Aug 2022 Posts: 19 | Looks like these videos will help get it running again. If only the last person who serviced the transmission would’ve not forgotten the speedometer drive gear and spacer🙄 | | |
