1 members (delky),
127
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2022 Posts: 62 'Bolter | | 'Bolter Joined: Jul 2022 Posts: 62 | 1954 Chevy 235ci. How do you service the road draft tube? Take off and soak in kerosene? I could not find anything with the search engine. 1953 Chevy 3100I have recreated my Dad's old work truck with a 5 window.Photos | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Redbird, that sounds good to me kerosene, varsol any good cleaning solvent let it soak for a couple of days and then flush through it. Have a look at it with a flashlight when you get it off, it may not be too bad. | | | | | Joined: Jun 2022 Posts: 558 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 558 | Back in the day they burned it out. Used a torch or simply stuck it in the fire. That's how I have done two of them and when I fire up the wood furnace next month I will burn off the one for the 54 3100.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | First use anything non-petroleum that is made to loosen up sludge, rinse it out and try again.
I was cleaning one for weeks then realized it was impacted badly. I tried kerosene, it helped a little but not enough. I put it in a old washing tub outdoors and away from anything that would catch fire. I got the tube hot with a propane torch. The sludge self ignited and burned itself clean (white inside). It sounded like a small jet engine. It belched a lot of black smoke and I suspect it was toxic. Be careful if you try this folks. Hours later after it cooled down, with respirator on I blew it out several times with an air hose. Then I sprayed some lube inside to keep it from rusting then wiped the exterior down with lacquer thinner. Primer and paint then reinstalled. The engine ran better.
I got lucky with the sequence. Right after cleaning the draft tube, I replaced the valve cover and lifter oil galley cover gaskets (the traditional way, including flattening the sheet metal). Hey! The oil leaks went away. Only a slight weep typical of all cork gaskets.
Will the draft tube sludge up again. On an engine with worn piston rings, you betcha.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Jul 2022 Posts: 62 'Bolter | | 'Bolter Joined: Jul 2022 Posts: 62 | Thank you guys. We don't dare light a fire around here at this time. We are under a "fire ban""! 1953 Chevy 3100I have recreated my Dad's old work truck with a 5 window.Photos | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Is this something that should be routinely checked on my 49 3100 w52 216?
Ed
| | | | | Joined: May 2015 Posts: 11,168 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,168 | Is this something that should be routinely checked on my 49 3100 w52 216? Probably only if it starts blowing oil vapor out the valve cover vents.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | If it was, it would be in the shop manual. You have to consider that many of these old truck engines are well passed their normal service life. Nobody wants to rebuild them, especially the 216, because of the expense.
If this is something that really bugs you, you could buy a used one to clean and swap out.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | First use anything non-petroleum that is made to loosen up sludge, rinse it out and try again. ...
... I'm glad you made that comment. The way mine is marking its territory, I should clean my road draft tube out- I know it won't fix a real leak, but anything to discourage the oil from looking for the exits could help. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | buoymaker In the olden days we burned those out with gasoline till we could knock out the sludge chunks !! | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I converted mine to a PCV and ran a pipe off of that to the manifold.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | WEb old PCV is best ,If there is a slight suction at the oil leaks may help keep oil in,however it's important to not put a vacuum on the crankcase. It will give you a funny feeling when it colapses the tin wear on your engine !! | | |
