3 members (Bill Hanlon, ShopRag, 1 invisible), 67 guests, and 1 robot.
Topics128,049
Posts1,055,676
#1462794 08/15/2022 11:23 PM
How many quarts of oil does a 54 passenger car 235ci with an oil filter take? 5 or 6 quarts?
1953 Chevy 3100
I have recreated my Dad's old work truck with a 5 window.
Redbird #1462795 08/15/2022 11:28 PM
Just fill it up until it reaches the full mark on the dipstick and then fill up the filter. Probably 6 total.
1950 Chevrolet 3100 (Ol' Roy)
Redbird #1462811 08/16/2022 2:00 AM
Sounds right!
1953 Chevy 3100
Redbird #1462812 08/16/2022 2:08 AM
My dipstick was not stock. I put in 6 qt of oil (I have a filter) and filed a notch on the dipstick where my "full" would be.
AD Addict & Tinkerer
My dipstick did not match the oil level either. I added 4 qts to the newly rebuilt engine, then filed a line for the low level, added another quart and filed a full level line. My engine at the time did not have a bypass filter. I’ve added one since.
Phil
Project Journals
Stovebolt Gallery Forum
Redbird #1462846 08/16/2022 2:22 PM
Some excellent info in this thread. I verified my dipstick accordingly:
https://www.stovebolt.com/ubbthread...stick-length.html#lg=1410855&slide=0
Adding the theoretical capacity of 6 quarts tends to overfill my engine. Not sure why. Perhaps sludge buildup in the pan. So I add 5….run the engine to fill the filter canister….and then top off.
1951 3100
Redbird #1462854 08/16/2022 3:37 PM
Curmudgeon
Curmudgeon
The oil filter (canister and cartridge) was an option you could purchase from the factory or later at the dealership.
Options were 1 quart (cars and trucks) and 2 quarts (big trucks).
For the engine only, 5-1/2 quarts for dry (no oil in pump etc.) and 5 quarts for refill:
http://chevy.oldcarmanualproject.com/chevyresto/5436.htm
After the oil and filter change or first filling, you prefill the canister to the amount required by the type canister.
Redbird #1462893 08/16/2022 7:26 PM
Redbird On your oil level,if you keep it right on full you may have more trouble with rear main leaks,especially if you don't have positive crankcase ventilation. Had one once that dipstick was wrong got ready to do a rear main abortion,drained it liked to run my pan over. Once that happened I knew what it needed,after that was fine not perfect,they drip a little.
Redbird #1462969 08/17/2022 4:03 PM
Curmudgeon
Curmudgeon
Fixite7, I'm having a very hard time figuring out what you are saying.
1.) The GM engine designers put the dipstick full mark in the wrong location?
2.) Someone put the wrong dipstick in your engine which caused you to overfilled it with oil?
3.) If you overfill the engine with oil, the rear main seal will leak?
Redbird #1463003 08/17/2022 9:12 PM
Check the attachment, below, for 1940-1961 Chevrolet dipstick lengths.
Redbird #1463005 08/17/2022 9:22 PM
If you discover you have the wrong one you can buy the right one for 75 cents.
Redbird #1463019 08/17/2022 11:27 PM
I may have to drain a quart. I put in 5 1/2 qts to take into account the oil filter. So the dip stick reads full. The 53 Truck Manual says 5 qts, but nothing about the filter. Guessing 5 qts only. So your dipstick would read a little low. Since I have a 54 Passenger car motor, I would guess the same.
1953 Chevy 3100
Redbird #1463043 08/18/2022 11:53 AM
Your oil dipstick may not be correct. Mine wasn’t and I remarked the stick. 5 quarts without the filter is correct.
Phil
Project Journals
Redbird #1463066 08/18/2022 6:06 PM
If any of the following parts are not original equipment (original specifications), you will most likely not get a good/true reading:
dip-stick length
dip-stick tube length
oil-pain depth and/or capacity
Redbird #1463077 08/18/2022 7:44 PM
I think you'll be fine.
Run the engine to get the oil filter filled up then check it cold. Dipstick should read full and filter will have about 1 quart in it. 6 qts total.
Redbird #1463080 08/18/2022 8:05 PM
Something fishy here.
My dipstick is 13 7/16 - 13 13/16 between the relevant points. Those numbers correspond most closely to the 53-55 Corvette.
5 qts fills it to the full line and about 1 qt fills the canister. What gives?
I guess I better see if I can scrounge up the engine numbers to see if it came from a Corvette?
Otto,
The '47-'55 truck, '49-'54 passenger car and '53-'54 Corvette dipstick dimensions to the marks are all the same. Chevy spec'ed those at 13-5/16" and 13-13/16". I've attached the chart from the '62 Chevy Chassis Parts Catalog (found in group 1.516) for reference. In that catalog, only one P/N - 3701556 - is listed covering all of those engines. There's nothing unique about the Corvette dipstick dimensions.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
Redbird #1463177 08/19/2022 3:02 PM
I see. I didn't notice the listings above Corvette were for the same stick.
Redbird #1463186 08/19/2022 4:10 PM
B Online: Content
... but the Corvette dipstick will make your truck faster wink
Redbird #1463219 08/19/2022 9:11 PM
…and much more valuable! headscratch
Phil
Project Journals
Redbird #1463225 08/19/2022 10:24 PM
Curmudgeon
Curmudgeon
While you guys are having fun "dipsticking", make use of those brain cells:
Should you prefill the canister reservoir with oil, after cartridge change, are let it fill from the inlet hose when the engine is restarted?
Redbird #1463237 08/19/2022 11:35 PM
As long as you don’t fill the canister past the small oil return hole in the central return pipe, it won’t raise the oil level in the crankcase.
Phil
Project Journals
Redbird #1463281 08/20/2022 12:58 PM
Curmudgeon
Curmudgeon
True. Now, what happens if you don't prefill?
buoymaker #1463289 08/20/2022 2:03 PM
The oil level will go down the same amount that the filter takes but I think you already know that!
Phil
Project Journals
Redbird #1463300 08/20/2022 4:28 PM
Curmudgeon
Curmudgeon
There was a discussion about this point in another forum. A guy remembers that his boss (auto garage) telling him to always prefill. I think the reason was a solution to head-off a possibility of a human mistake.
If you don't prefill you have to wait until the reservoir fills. Wait for the oil to travel through the 1/16" hole in the tube and down the hose back into the engine. It shouldn't make any difference in the oil pressure and bearing lubrication at idle speed. Assuming you first filled with 5-1/2 quarts and not 6 quarts to avoid overfilling. Stop the engine and add oil to the full mark. Run the engine and check again. Maybe repeat again several times. Prefilling can save time and maybe prevent under and over filling.
On modern engines with full flow oil filtration, the oil circulates in what seems like seconds.
buoymaker #1463328 08/20/2022 8:55 PM
buoymaker I'm just saying that if the oil level is right up there level with the seal more likely to leak. Same way with the differentials,that oil level is just below the seals but when you drive the oil level will give the seals a "drink"when you get not level,once back on the level it equalizes. The hubs have a pocket that holds oil for bearing lube,it gets changed as you drive and get out of level at times. It's not that the dipstick is wrong,but pans get changed,dipsticks get changed,dipstick tubes get changed. Item 2 and 3 happened to my one ton,when I drained it I got way too much oil,well PO put in a dipstick tube to tall raised oil level above rear main seal !! Would leak sitting in the shed.
buoymaker #1463774 08/24/2022 12:27 PM
buoymaker I usually check my oil first thing while it's cold,then add oil till it approaches full. Would rather be slightly low rather than slightly high. Filter will be at the level of it's drain back hole,system will be ready for service.
