3 members (keithfielder, Stewart2, Rich'sToys), 122 guests, and 2 robots.
Topics128,103
Posts1,056,534
Members48,448
#1462965 08/17/2022 3:38 PM
Any thoughts about this weird electrical issue please...?
I let my friend drive my 55.1 235 5sp 12v pickup. He stalled it out. After that, it won't start.
When I turn the key, the electric fuel pump starts buzzing. Then I hit the foot starter, the fuel pump quits and dead silence. No starter noise.
It seems like pressing the starter pedal kills all power.
Any ideas?
DonBolt
1955.1 3100
235, 12v, 5-window, 5 speed
Turn off the electric fuel pump and see what happens when you push the starter button.
1950 Chevrolet 3100 (Ol' Roy)
Sir Searchalot
Sir Searchalot
That there is your standard dead battery/bad cell/corroded battery posts/corroded cables/corroded cable clamps/loose clamps/corroded connection at starter/failing ground strap or cable/failing foot starter switch, possible bad starter ...........or maybe something else. smile
1. Check battery for 12.6V at rest. report number
2. Check battery voltage during foot pedal press, see if voltage drops way down or no change. report number.
3. Check all those connections
4. 5 speed? Electric fuel pump?
5. If numbers not good at battery check, take battery to good FLAPS for load test.
6. Report above to continue tests. Use volt meter/multimeter set to DC volts.
Ignition switch not involved
Charging system not involved
The bad battery or corroded termination breaks down when starter draws 450 Amp +. You are noticing the pump because it's the only thing that makes noise when ignition switch is on. If you had headlights on, they would go off also.
I'm with Bartamos.
To add to his list:
2a. Check voltage at the battery CLAMP (not on the post) during foot pedal press. See if voltage drops way down or no change. report number.
Or just right off the bat remove the battery cable clamps and clean the posts and clamps and reinstall and see what happens.
Sir Searchalot
Sir Searchalot
............or jumper cable it with another 12V vehicle for a second or two. just to get some hints on what it wants.
Thanks guys. Battery read 3.4v, so I'm charging and will report back later. All your advice seems on target! Thanks. Don
DonBolt
1955.1 3100
Follow up on my "starter"...
Yes, as Bartamos said, it was the classic low battery symptom.
No, the fuel pump didn't buzz nor did lights work when I pressed the starter button.
My first meter check showed 12.3v, then 12.86v after a partial charge. The starter turned at 12.86v.
Thank you Stovebolters. Another mystery solved.
Gratitude,
Don
DonBolt
1955.1 3100
Sir Searchalot
Sir Searchalot
I fear battery may go dead again. It's either bad cell
or charging system not charging, So when motor running, check voltage at battery for about 14V at 1000-1500 RPM
I will check voltage with motor running as you suggest.
Please forgive my typo. My lowest battery voltage earlier today was 12.34v. (Not 3.4v).
DonBolt
1955.1 3100
If the voltage was low when he was driving (when it stalled out), that typically indicates a problem with the charging system that will leave you stranded again.
Recommend checking that sooner than later.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
