8 members (J Lucas, Hotrod Lincoln, dt235sd, 1955 1 Series, Gdads51, 55shaker, Lightholder's Dad, wilbur53), 81 guests, and 3 robots.
Topics128,079
Posts1,056,297
Members48,441
I know this may sound like a dumb question, but can anyone provide me tips on installing the push-on (not threaded) 3-speed gear shift knob for my ‘39 1/2 ton pickup? The hole in the knob is much smaller than the shaft and does not easily press on. I’m afraid that if I force it on, it will shatter.
Thank you!
Mike
1939 1/2 ton Chevy
Maybe put it in boiling water for a bit to heat it up and expand it?
Or drill out the hole so it's an easier fit and glue it in place?
Ex Hall Monitor
Ex Hall Monitor
It's supposed to be a tight fit but sounds a bit too tight. If it was me I'd take a drill bit and make the hole larger.
I had the exact same problem with my 1940 half ton years ago. I do remember that I drilled it out and glued it on. I don't remember what kind of glue I used, but it's still on there and has never been a problem.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Ex Hall Monitor
Ex Hall Monitor
Shouldn't need to glue it. It's a push fit.
I threaded the shifter rod and tapped the knob to screw on the rod.
1936 GMC T-14 1/2-Ton Pickup
Thanks for all of your tips, everyone! I’m going to drill it out and see if I can get it to fit. Take care and thanks again!
Mike
1939 1/2 ton Chevy
