| | | Forums66 Topics128,090 Posts1,056,026 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 4 Junior Member | | Junior Member Joined: Mar 2006 Posts: 4 | My C-60 sat for about 8 years, and I decided to get it running again. I got the engine running with no problem, and i got the hydraulic that operates my dump bed working with no problems at all.I also got the brakes working to, but the Hydrovac Brake Booster is not coming on to assist the brakes.Can anybody point me in the right direction as what i need to do. Any suggetion would be appreciated
Trey Deluna
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | check for bleeder valves on hydrovac unit | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Check for vacuum at the booster. Make shure the breather is clean. It,s usually in the cab behind the seat. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | These boosters rust up or stick when setting around. I drove my 54 for almost 5yrs without the unit working. Let it set over winter, and next spring it started to work by itself again. Rebuilds are expensive, and if a Midland, you have to send out, they won't sell you parts. Yes, you can drive w/out boost, just brakes harder, and have to start slowing earlier, than if you had working unit.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
