5 members (JW51, C10 - C90 Bill, Gray_Ghost, Leo, Hotrod Lincoln), 111 guests, and 2 robots.
Topics128,100
Posts1,056,177
Members48,436
Not sure when they were replaced, but look dried out and brittle to me. I have purchased replacements. Any tips to tackle this one? It looks like you need to hold the line up by the clip, and use a line wrench on the steel line. Anys tips on breaking them loose. Also tips on the bleeder valve on the wheel cylinder. I don't want to round it off trying to loosen.
1953 Chevy 3100
I have recreated my Dad's old work truck with a 5 window.
Yes, you need to use a back-up wrench when removing lines. Get a set of line wrenches (box style with a cutout so you can slip the wrench over the tube, then on to the nut.)
On bleeders, use a box wrench (6-point if you have one) or the above mentioned line wrench.
Thank you. I don't want to twist or break the steel line.
1953 Chevy 3100
I use a small six point socket to crack the bleeders initially.
1951 1 Ton Completed
' Offline
Give the bleeders a shot of PB Blaster a day or two before you try to open them.
