| | | Forums66 Topics128,088 Posts1,056,124 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2022 Posts: 62 'Bolter | | 'Bolter Joined: Jul 2022 Posts: 62 | Not sure when they were replaced, but look dried out and brittle to me. I have purchased replacements. Any tips to tackle this one? It looks like you need to hold the line up by the clip, and use a line wrench on the steel line. Anys tips on breaking them loose. Also tips on the bleeder valve on the wheel cylinder. I don't want to round it off trying to loosen. 1953 Chevy 3100I have recreated my Dad's old work truck with a 5 window.Photos | | | | | Joined: May 2015 Posts: 11,065 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,065 | Yes, you need to use a back-up wrench when removing lines. Get a set of line wrenches (box style with a cutout so you can slip the wrench over the tube, then on to the nut.) On bleeders, use a box wrench (6-point if you have one) or the above mentioned line wrench.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2022 Posts: 62 'Bolter | | 'Bolter Joined: Jul 2022 Posts: 62 | Thank you. I don't want to twist or break the steel line. 1953 Chevy 3100I have recreated my Dad's old work truck with a 5 window.Photos | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I use a small six point socket to crack the bleeders initially. | | | | | Joined: Oct 2019 Posts: 131 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 131 | Give the bleeders a shot of PB Blaster a day or two before you try to open them. | | |
