6 members (32Fordpuchoptop, Youngin' Tut 59, treegrower, Gray_Ghost, Wickedbass, WICruiser), 66 guests, and 3 robots.
Topics128,076
Posts1,055,922
Members48,430
#1460580 07/29/2022 1:54 AM
I just got my truck back from the fab shop. Now the problem I see is it's hot in that cab. It doesn't have any heat insulation of any kind. What are your suggestions? I'm heading to the upholstery shop soon.
I'm mainly concerned with the firewall and floor. But I'd do the whole inside.
I use peel and stick roof flashing from Lowes or Home Depot. It has adhesive on one side and aluminum on the other, with black rubbery material in between. It is similar to the high dollar Dynamat except but it is not as thick. It has worked fine for my '49.
One thing about keeping heat out of the cab is having tight felt seals on the pedals and sound grommets in the firewall. I use black RTV to fill any gaps in the grommets.
Do something about the roof while you are at it. Your head will be fairly close to it and heat will radiate through. I used duct work insulation, the grey sticky back foam 1/4" thick from Home depot.
Hush Mat. Sound and heat insulation
https://hushmat.com/
Go with a two tone paint job - white roof.
1950 Chevrolet 3100 (Ol' Roy)
AD Addict & Tinkerer
I used Kilmat in my doors and plan on using it on the rest of the cab. Simlar to dynamat at but much lower in price.
Phil
Project Journals
Stovebolt Gallery Forum
We do very few non ac rides (it's Texas) but when we do we first spray with Lizard Skin then use a Dyna-Mat type deadener/insulation followed with the jute mat and finally the rubber mat or carpet. Fairly quiet but hot as hell on 100+ days.
Evan
Coilover,
Hard to keep cool in Texas heat!
I used dynamat, the bubble insulation with foil, jute and carpet. Mine still gets toasty. One add that really helped was ceramic window coating!
Chris
Chris
Was that a film or spray on type?
Phil
Project Journals
Sooo, how many sq. ft. to do the interior of a 36 pickup?
1936 GMC T-14 restro-mod
I think you mean cubic feet (volume).
Unless he intends to fill the entire cab with insulation wink , he does mean square feet. The area on the inside of the cab.
I thought he needed the volume of air in the cab for HVAC purposes. Confused with a different thread.
Haha! Actually a different thread on a different forum!
Moderated by  ndkid275, Phak1
