6 members (Otto Skorzeny, Shade Baby, Phak1, EchoBravoSierra, BarryP, 46 Texaco), 152 guests, and 1 robot.
Topics128,162
Posts1,056,910
Members48,458
Until I can get my stock steering wheel horn squared away, I’m hoping to temporarily put in. 6v universal horn button. In looking at the ‘39 wiring diagram, I see that one wire from the horn is connected to power from the ammeter and the second wire goes to ground. Since I’ll be running new wires to the universal horn button, I’m not sure where the ground wire connects to ground so I’m hoping someone can give me a pointer on where I can connect the universal horn button’s ground wire. Thanks so much!
Mike
1939 1/2 ton Chevy
Red dot, center of chest ...
Ground should be anything metal on the truck. You can check that with an ohmmeter.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Sir Searchalot
Sir Searchalot
As Paul says...... Hot wire to horn, no change. New wire from horn ground terminal to one terminal of new button. Wire from other button terminal to nearby clean metal spot. You can check that by pushing button.
bartamos, your sig is a mouthful. Funny, but a mouthful.
Paul Schmehl CI 6
geek@stovebolt.com
Sir Searchalot
Sir Searchalot
Do you want me to cut it down? I will if it's too much.
Thanks very much, baldeagle and bartamos! I appreciate the assistance!
Take care!
Mike
1939 1/2 ton Chevy
