6 members (Youngin' Tut 59, Cletus1950, 1955 1 Series, 37 GC, Mike Roache, 1 invisible), 119 guests, and 3 robots.
Topics128,147
Posts1,056,806
Members48,454
Hi All, my truck is in sig below. Is there any recommendation for protecting the under dash components of these trucks from a potential rainstorm /water getting on them. I am talking about after doing due diligence and in the case where you get a leak and water in some form hits the ignition switch/fuse box or something else.. nono I understand theres all types of grease but one conducts and the other doesnt and you dont want to smear the one conducting , all over the fuses and end up shorting out the whole truck OR the one that protects and then the components dont work. dang. . So is there a few recommendations on the types of products or how to use them? wave
'38 1.5ton; "The stuff is as tough as woodpecker lips"
The first step would be making sure that water doesn't get to the electrical components in the first place. Dielectric grease could be used. Generally there won't be enough water to short out things, and rainwater shouldn't affect the primary (low voltage) wiring at all, but could possibly short the coil and spark plug wiring. A little dab of dielectric grease (mainly on the boots) will help with that. Definitely don't smear either type all over things.
Reminds me of when I was driving my Model A pickup across Kansas back in '68 when we saw a wall of water from a rainstorm coming. When it hit we couldn't see more than about 3 stripes on the interstate and the truck died from the water leaking down onto the coil, which was mounted directly below the hood hinge. I got out, was immediately soaked to the underwear, threw a tarp over the hood, dried off the coil and wiring, and restarted (still with the tarp over the hood) and found the nearest overpass to wait out the storm.
Ok. Thanks for the reply. Wow that must hv been scary with that model a!
Hey, I was young and indestructible back then. No big deal. wink
